CollinW
- Mar 9, 2023
- 10
I am attempting to analyze a monorail beam that is supported from above with vertical HSS tubes. It has 5 points of support, 4 internal spans, and one cantilever span at the end. Per the steel manual F1 and App. 6.3 the beam must be restrained against rotation in the longitudinal axis. This beam does not have any bracing along the bottom flange, so the only option that I see is to check it for Torsional Bracing per Eq (A-6-9) and (A-6-10). However, Eq. (A-6-11) has the variable "n" that doesn't seem to apply in my case because there are no braces in between supports. When I use n=1 and L="each span" then the calculation works, however when I try to do something like n=3 and L="sum of spans," it fails.
I was wondering what other people thought of this and if anyone has run into this same issue. None of the other equations in App. 6 have this "n" variable. The structure and beam have already been built, but no lifts have been done yet.
