ENGJP22
- Nov 2, 2020
- 35
Hi Guys, the torsion diagram that the ETABS shows its simply the the moments transfered by the slabs to the beam? I have a concrete beam between two slabs and I want check if the program is taking the correct decisions because it shows O/S #45.
The beam have one 4mx5.5m slab at one side and a 4mx4m slab on the other, the 4m dimension is parallel with the beam.
