Good day. I'm analyzing the top chord of the open web steel joist in compression. The top chord is cold-formed hat channel and mode of failure in compression is torsional buckling. This top chord is connected to metal roof deck and I'm trying to figure out what can be considered as adequate torsional restraint of this member and what capacity this torsional restraint should provide.
When estimating the torsional restraint moment, would it be reasonable to take it as lateral buckling force in this member (2% of compressive force) acting at the shear center and multiply it by the distance between the shear center and center of gravity of the member?
