1986ammu
- Sep 5, 2019
- 3
I hope i will find some engineering solution in ENG-TIPS.com
Issue : Tower crane Anchorage tie back support forces calculations.
As a standard practice every crane manufacturer will provide crane manual along with the product.
It contains all the parts & procedure etc. It also contains Reactions on foundation , on anchorage frame etc.
Whenever the user want to increase the crane height, they will provide some anchorage tie back support between crane & the construction building. So to design tie back supports , the consultants are using the Reactions given as per manufacturer.
My i know what exactly do with these reactions & how they are going to calculate?
Can we use Staad Pro to calculate the stress & forces to design the tie back supports?
