Where can I find information about working with trail files.
How to edit these files.
Is it possible to run a part of a file.
What to do if there is an error?
I would start with the help structure within Pro/e. Then check the links on this site. I have some documents at home on trail files that I've gathered over the years. I will repost last.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
You can edit them in wordpad. There is nothing special with trail files. All clicks and movements of your mouse are recorded in this files as well as the menu browsing. A quick study will give you an ideea of what info you need to keep if you want to modify it.
Make a copy of the file you want to edit, but remove the number afer the second dot (ex: trail.txt.49 -> my_trail.txt) This file can be run in ProE.
Does anyone know the correct procedure when working with a trainer text file and a trail file. The help in Pro E is not as descriptive as it should. Thanks. Don
