Trane Trace
ssn61
72
How should a 100% outside air air handling unit be modled in Trace?
I have found where it says "100% outside air" in the airflow template section, but is that all it needs to be done?
Call Trace support and tell them exactly your setup and they will walk you through it. There are many variations of systems and no single answer.
However, for the simplest system, it is possible that setting 100% OA at the airflow template is all you need to do.
