said the noob
contractor has wanted to pour 1700mm dp transfer slab in two lifts, first lift being 900mm dp and second lift being 800mm dp, horizontal shear is minimmal as the horizontal shear plane is quite close to the COG of the entire 1700mm section.
but they had also mentioned that the slab will be destressed after the first lift, and then retensioned prior to the pouring of the second lift,
anybody know what is the purpose of the destressing and retensioning of the formwork pior to the second lift? they intend to pour the first lift in day 1 and then destress/retension, then day 2 will pour the second lift, shoring of the full 1700mm dp slab will be provided,
can anybody shed some light on why they are doing this? and is it allowed? it would seem the first lift 900mm dp slab would not have reached the required strengths to destress, at that point it would have to be self supporting of its weight during the brief moment is destressing/retenstioning.
TIA
TIA
