Reference to AISC design guide 1 second edition,
There are three principal ways of transferring shear from column base plates into concrete:
1. Friction between the base plate and the grout or concrete surface.
2. Bearing of the column and base plate, and/or shear lug, against a concrete surface.
3. Shear in the anchor rods.
My question, if I have a big value of shear force at the base which cannot be resisted by shear lug separately, could I resist part of the shear force by friction and the remaining one to be resisted by shear lug?
Example: Ultimate shear force (Vu) = 8847 kN, ultimate compression force (Pu) = 7796 kN
available shear strength (phi*Vn) = 0.75*0.55*7796 = 3215 kN
Required shear to be resisted by shear lug = 8847-3215=5632 kN.
