Transformer Rewind
electrageek
116
The local Utility has decided we need to change the highside voltage on our 1000KVA service transformer from 12.0kV to 13.2kV. The configuration is Highside Y to Lowside Y with the low side being 480V. I was wondering if anyone has had experience in this area?
Google is your friend.
Try the surplus record.
Link
One example-
Surplus Record. said:
750/1000 KVA 13200 Delta Pri. 480Y/277 Sec., Square D, #DRY3960 Visit Dealer's Equipment Listings RFQ
Sunbelt Transformer,
You may also use the surplus record to sell your surplus transformer.
Bill
"Why not the best?"
Jimmy Carter
