deetz
- Nov 19, 2010
- 89
We are replacing a new CNC machine and the transformer we had for the old one is 45kva. The new machine is 123 amps at 220 volts. It's also rated for 205-235 volts. That equates to 46.86 kva. Will the 45 kva transformer be okay? I know the usual machines tend to run lower than the actual amps. Also what about NEC compliancy? I suppose if you have it fused right you would be?
