Hello all,
I wanted to gather thoughts on a particular trend that has been observed. The trend is as follows:
When a transformer is isolated and then energized, the longer the transformer was in isolation for, the higher the inrush current peak magnitude. Effectively, if the transformer was energized after a few days in isolation then the peak is lower than if it had been in isolation for several weeks.
I see this as a very interesting trend to try to explain. The thoughts of my team are aligned with it having to do with how a transformer can gradually lose the residual flux in its core, and somehow having less flux in the core begin connected to a higher inrush current upon energization. The literature I have come across on the subject does not support this idea though, as the inrush current peak should be smaller as the residual flux in the core decreases.
In addition to this, I found some nifty discussions on prefluxing of a transformer core before energization. This effectively requires the core to already be saturated before energization, and it has shown to significantly reduce the peak of inrush current in simulations if point-on-wave switching is used as well. I was thinking that this might harbor some kind of explanation for the trend, but I am not sure how a core would remain saturated for up to days after isolation.
Let me know what you think about how to explain this trend.
Tstuhl
Tstuhl
