EnergyProfessional
- Jan 20, 2010
- 1,279
In 1-2 years support for T700 will end. I had used it for multiple years for load calculation and energy simulations. It has its limitations, but it works. any error is easily resolved.
The real only limitation is that one enters the rooms manually without "seeing" the building. gbXML also is clunky and needs a lot of corrections. other than that, it just works. system and plant setup is easy and errors are obvious.
I had tried "IES VE 2019" and "Trace 3D Plus". Both of them are front ends to EnergyPlus. The only nice thing I have to say is that they have a nicer way of creating the building and you can "see" the building.
Both of them are clunky, come up with un-resolvable errors that are hard to trouble-shoot and so on. they feel like they need some more years of development. And that is before i even try complex buildings and systems. I'm a heavy Revit user, also use EES and so on. So I'm not a luddite.
Did you guys come across load/energy software that works as well as T700, but with a more modern UI to create the building? or what is your experience if you also used T700 and tried IES VE and Trace 3D?
