"I would like to mesh one sheet thickness of 1 mm, length 400 mm and width 300 mm, in the same way as shown in the attachment.
In the direction of the width "300 mm", 1 element becomes 4 elements at the passage of a "transition" zone, then the 4 elements become 16 elements at the passage of a second transition zone.
Can you help me? I use Abaqus.
Thank you."
Thank you."
