translate SolidWorks Assembly from foreign language to English
Christopher Torres
I currently working on a huge assembly that has multiple subassemblies and I was wondering if somebody could help modify this code (below) to translate all the features, planes, material, etc... to English.
I found this code in another previous tread and for some reason, I did not let me reply to it.
Thank you in advance.
Hi Deepak,
I've missed the material issue.
Please take a look at this modified macro which considers the material name as well as standard reference geometry names. I've created four constants for their names.
Please do not hesitate to as a question if you have ones.
Dim swApp As SldWorks.SldWorks
Dim swPart As SldWorks.PartDoc
Dim swFeat As SldWorks.Feature
Dim newName As String
Dim dicFeatsCount As Object
Dim collFeatsNonIncr As Collection
Dim dicBaseNames As Object
Const FrontPlane = "Front Plane"
Const TopPlane = "Top Plane"
Const RigthPlane = "Rigth Plane"
Const Origin = "Origin"
Dim isRefGeom As Boolean
Sub main()
Set dicFeatsCount = CreateObject("Scripting.Dictionary")
Set collFeatsNonIncr = New Collection
Set dicBaseNames = CreateObject("Scripting.Dictionary")
isRefGeom = False
'Add the list of features which shouldn't be incremented
collFeatsNonIncr.Add "SensorFolder"
collFeatsNonIncr.Add "DocsFolder"
collFeatsNonIncr.Add "DetailCabinet"
collFeatsNonIncr.Add "MaterialFolder"
collFeatsNonIncr.Add "OriginProfileFeature"
'Add the list of predefined base names
dicBaseNames.Add "MaterialFolder", "Material <not specified>"
dicBaseNames.Add "OriginProfileFeature", "Origin"
dicBaseNames.Add "ProfileFeature", "Sketch"
dicBaseNames.Add "Extrusion", "Extrude"
dicBaseNames.Add "RefPlane", "Plane"
Set swApp = Application.SldWorks
Set swPart = swApp.ActiveDoc
Set swFeat = swPart.FirstFeature
While Not swFeat Is Nothing
If dicFeatsCount.exists(swFeat.GetTypeName2()) Then
dicFeatsCount.Item(swFeat.GetTypeName2()) = dicFeatsCount.Item(swFeat.GetTypeName2()) + 1
Else
dicFeatsCount.Add swFeat.GetTypeName2(), 1
End If
If dicBaseNames.exists(swFeat.GetTypeName2()) Then
newName = dicBaseNames.Item(swFeat.GetTypeName2())
Else
newName = swFeat.GetTypeName2()
End If
Dim i As Integer
Dim isIncremented As Boolean
isIncremented = True
For i = 1 To collFeatsNonIncr.Count
If collFeatsNonIncr(i) = swFeat.GetTypeName2() Then
isIncremented = False
Exit For
End If
Next
If isIncremented Then
newName = newName & dicFeatsCount.Item(swFeat.GetTypeName2())
End If
If swFeat.GetTypeName2 = "MaterialFolder" Then
isRefGeom = True
Dim sMatName As String
sMatName = swPart.GetMaterialPropertyName2("", "")
If sMatName <> "" Then
newName = sMatName
End If
End If
swFeat.Name = newName
Set swFeat = swFeat.GetNextFeature
If isRefGeom Then
swFeat.Name = FrontPlane
swFeat.Name = TopPlane
swFeat.Name = RigthPlane
swFeat.Name = Origin
isRefGeom = False
End If
Wend
End Sub
