transparency 1
lapek
Aerospace
MX
hi every one
here again giving trouble to all of you guys, I want to get my solid transparency, and I found a command SetRealOpacity but some how I can not set it
here is the code im using
CATIA.ActiveDocument.Selection.Clear
Set objsel = CATIA.ActiveDocument.Selection
objsel.Search "Type=Topology.Face,all"
objsel.SetRealOpacity 255, 1
icnt = objsel.Selection.Count
ReDim MySurface(icnt + 1)
For o = 1 To icnt
Set MySurface(o) = objsel.Item(o).Value
Next o
Dim spabench As SPAWorkbench
Dim mymeas As Measurable
Dim centroide
Dim ref1 As Reference
Dim myans As Double
Dim InputObjectType(0)
Dim variable As String
'*******************Toma Fotografia de la Superficie Seleccionada***************
For o = 1 To icnt
Dim ObjViewer3D As Viewer3D
Set ObjViewer3D = CATIA.ActiveWindow.ActiveViewer
Dim objCamera3D As Camera3D
Set objCamera3D = CATIA.ActiveDocument.Cameras.Item(1)
Dim j
CATIA.ActiveDocument.Selection.Add (MySurface(o))
'Ubicacion del guardado de la imagen
Dim fileloc As String
fileloc = "C:\Users\Lab3\Desktop\Fotos\"
Dim exten As String
exten = ".jpg"
Dim strName As String
strName = fileloc & CStr(o) & exten
Dim objSpecWindow As SpecsAndGeomWindow
Set objSpecWindow = CATIA.ActiveWindow
objSpecWindow.Layout = catWindowGeomOnly
CATIA.StartCommand ("Compass")
'Toma la Fotografia
ObjViewer3D.FullScreen = True
ObjViewer3D.Viewpoint3D = objCamera3D.Viewpoint3D
ObjViewer3D.CaptureToFile 5, strName
ObjViewer3D.FullScreen = False
objSpecWindow.Layout = catWindowSpecsAndGeom
'ObjViewer3D.Viewpoint3D = objCamera3D.Viewpoint3D
Next o
its just a section, what I need it to get the solid transparent, and then in the cicle remove the transparency of the selected face and give a color,
hope you can help me with this,
thank you for your time
This is from CATIA Portable Script Center, maybe you will get some other ideas.
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
Text = InputBox("After click OK you will see Rendering mode 0 = shading Gouraud", "RenderingMode", "RenderingMode 0", 150, 9000)
viewer3D1.RenderingMode = 0
Text = InputBox("After click OK you will see Rendering mode 1 = shading Gouraud with edges", "RenderingMode", "RenderingMode 1", 150, 9000)
viewer3D1.RenderingMode = 1
Text = InputBox("After click OK you will see Rendering mode 2 = wireframe with edge lines", "RenderingMode", "RenderingMode 2", 150, 9000)
viewer3D1.RenderingMode = 2
Text = InputBox("After click OK you will see Rendering mode 3 = wireframe without hidden lines", "RenderingMode", "RenderingMode 3", 150, 9000)
viewer3D1.RenderingMode = 3
Text = InputBox("After click OK you will see Rendering mode 4 = shading Gouraud outlines with edges", "RenderingMode", "RenderingMode 4", 150, 9000)
viewer3D1.RenderingMode = 4
Text = InputBox("After click OK you will see Rendering mode 5 = shading with material without edge lines", "RenderingMode", "RenderingMode 5", 150, 9000)
viewer3D1.RenderingMode = 5
Text = InputBox("After click OK you will see Rendering mode 6 = shading with material with edge lines", "RenderingMode", "RenderingMode 6", 150, 9000)
viewer3D1.RenderingMode = 6
Text = InputBox("After click OK you will see Rendering mode 7 = shading with edge and hidden lines", "RenderingMode", "RenderingMode 7", 150, 9000)
viewer3D1.RenderingMode = 7
Text = InputBox("After click OK you will see Rendering mode 8 = shading Gouraud no smooth edges", "RenderingMode", "RenderingMode 8", 150, 9000)
viewer3D1.RenderingMode = 8
Text = InputBox("After click OK you will see Rendering mode 9 = wireframe no smooth edges no vertices", "RenderingMode", "RenderingMode 9", 150, 9000)
viewer3D1.RenderingMode = 9
Text = InputBox("After click OK you will see Rendering mode 10 = wireframe half visible smooth edges no vertices", "RenderingMode", "RenderingMode 10", 150, 9000)
viewer3D1.RenderingMode = 10
Text = InputBox("After click OK you will see Rendering mode 11 = shading Gouraud outlines with edges ", "RenderingMode", "RenderingMode 11", 150, 9000)
viewer3D1.RenderingMode = 11
Text = InputBox("After click OK you will see Rendering mode 12 = shading Gouraud outlines with edges no vertices", "RenderingMode", "RenderingMode 12", 150, 9000)
viewer3D1.RenderingMode = 12
Msgbox "And So On"
End Sub
Fernando
hi every one, never mind I solve the issue, thanks a lot
thank you for the post ferdo, I really get more ideas on this
you are awesome
