tree structure locked 3
TomMtz
147
Hi friends
I found an old 3D model of NX6.5, when I tried to modify the " main tree structure (I do not know the technical name)", the boxes for operatios, sketches , etc. are blocked.
(See attached picture), someone of you know, how can I get unblocked it?
thanks a lot for your comments
Tom
NX12 Windows 10 / Teamcenter 10
 https://files.engineering.com/getfile.aspx?folder=1c9fabdf-9835-4ede-9939-413c61074082&file=locked_boxes.jpg
From the image, the features you're referring to are 'suppressed by expression'.
However, you should still be able to edit those features.
Try Edit -> Feature -> Suppress by Expression, then delete the suppression to see if that makes any difference.
Anthony Galante
Senior Support Engineer
NX4 to NX CR with almost every MR (18versions)
It should still not be locked. ( these features can be , but are not currently, suppressed by an expression.)
But, Files from older NX versions ( such as NX6) DOES NOT have an application ( i.e Modeling) connected , - when you load an old file, you must also activate Application- Modeling.
Else you cannot modify the features.
Tomas
Try saving that file into the newest version of NX that you are running and see if you can decipher what is going on.
There may be easier ways to see when viewed in a new version.
In NX6 it was possible to suppress features by expression.
Jerry J.
UGV5-NX11
PhoeNX
jerry1423
Toost
Awesome, I followed your facts and I "unblocked" the operation.
step 1: save whit newer version
step 2: Edit -> Feature -> Suppress by Expression > Expression option [Delete for each] > show expression > select & delete
Thanks a lot for your time & kind regards
Tom
