Good afternoon ladies and gentlemen,
Consider a case whereby a vessel has been designed in accordance with ASME VIII-1. At a later stage, due to local metal loss for example, the vessel is re-evaluated in accordance with ASME VIII-2 part 5 rules with an FEA. As we know, Div. 1 uses Tresca and Div. 2 allow the use of von Mises yield criterion. So, upon re-evaluation after Div. 2 rules, will it be permissible to use the von Mises yield criterion?
Here is a short article which touches this topic.
Julian
Julian
