nikolastrojman
Industrial
Hi!
I would like to hear your thoughts/opinions on the subject matter stated in the title. Do you know what is the minimum angle of an elbow for a given NPS of pipe acceptable by the welder/pipe fitter to be used on site?
We are currently designing piping route on a sleeper way located on a sloppy terrain which sometimes requires to use trimmed/small angle elbows (i.e. 12° or 8°).
On the other hand, the client insists on avoiding this kind of elbows because it requires a lot of cutting/welding effort on site and it is also more expensive and time-consuming.
The code of design/construction of the piping in this project is ASME B31.3, so may question is also is there an angle in the code which defines a limit for using trimmed elbows?
