Engcan
- Dec 11, 2005
- 23
I am asking this question keeping in mind that no question is stupid. This might be drop in the ocean for you but these questions are bothering me. Please see below:
Q1 In case of selection of relays and circuit breakers for protective coordination, When it comes to molded case circuit breaker: Is it correct that they have their own TCC curves.
While in case of SF6 or Vacuum CB's, it is the relays TCC curves are used as relay will activate the CB. am I correct?
If yes is any time considered for the CT's.
Q2 Somebody suggested here a link on this website written below from bussman
this article talks about using current limiting fuses at every place. Is it true in practice also or depending upon the tolerance of the equipment being protected, we decide we have to use a current limiting or a normal fuse.
Q3 My last question, what is a lowpeak fuse and how do we decide while selecting fuses, who will be the manufacturer while doing design for example
: Cooper power, Bussman, Hubble .
I am sure this might take a bit of your time. I would appreciate, if you guys could drop few words.
