3dr
Automotive
- Jul 10, 2004
- 451
I've got a node locked license running on my local machine.
When working remotely, NX runs when not connected to the company VPN network.
But when connected it fails.
If I'm running NX when I connect, it will continue to run.
If you try and start a new session it can't find the license server.
Has anyone else experienced these types of issues???
Most folks are probably connecting to a license server on the network, thru the VPN.
I think that scenario works predictably well. It's your machine looking outward toward the server.
But when your machine is is the license server... it can create a naming resolution issue when you connect to the VPN.
Siemens tech support hasn't been much help and I'm ready to loose it.
TIA
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
TIA
Dave
NX11, Win 10 Pro
