Trunnion Mounted ball valve seat testing
tusharpatil9983
Industrial
Jun 17, 2016
I am seeking guidance on Hydrostatic seat testing. Currently, our testing procedure is as follows:
Step 1: Fill the cavity until water comes out from the vent port and then close the valve.
Step 2: Apply the hydrostatic test pressure from seat A (test pressure is 1.1 times the rated pressure).
Step 3: Observe the pressure on the gauge and visually inspect the vent port. (As cavity is filled if seat A is leaking then water will come-out of vent port)
I have two questions:
Is the above-mentioned test process in compliance with API 6D and API 598 standards? Or there is a different approach to inspect the hydrostatic test.
Following the above test procedure, we observed valve leakage visually (approximately 2-3 drops/5 minutes) from both sides individually. However, there was no leakage found in the Pneumatic seat test at 6 bar, and no leakage was found in the low-pressure Pneumatic seat test at 1 bar. How should we interpret these results to determine whether the valve is acceptable or not?
To answer your question we need more information.
1. What type of valve is this? Soft seated?
2. Is the requirement API 598 or 6D?
For API 598 A hydro seat test is not required unless specified by the customer. Also in API 6D a low pressure seat test is not required unless specified by the customer per Annex H.
