Justice100
Chemical
- Jun 18, 2008
- 49
Hello all,
I have a shell and tube HE with dense phase HC fluid on tube side at 350 barg and hot water on the shell side at 15 barg and 150 DegC with a design pressure of 24 barg. The shell will be protected by 2 bursting discs connected to the main flare header via tail pipes and a sub header for the tube rupture scenario. On tube rupture the dense phase fluid flashed to the lower pressure is almost all gas. I've worked out the steady state relief rate and we have a consultant doing the transient analysis on the scenario.
The one thing I am not sure about is when the tube rupture occurs and the bursting disc bursts then hot water will be pushed out of the exchanger but at this initial point the water in the tail pipe will immediately vaporize to steam since the flare sits at 0 barg. As this flow develops down the tail pipe/header a back pressure will develop eventually so the water won't vaporize. The shell volume is very small compared to the flare header.
I am trying to size the burst disc tail pipe and assess the flare header, which is fine for the steady state case but I am not sure what to consider for this transient case. Any ideas? Has anyone come across this before? The transient consultant was not much help...
