Nov 9, 2004 #1 alf238 Mechanical Dec 10, 2003 12 0 0 CA Hi everyone, I make a hole into a tube (the outside diameter of the tube is 8mm and the inside diam. is 5.5mm), 1mm radius. I want to see the shape of the hole after the tube is flattened. How to do this in UG NX? Thanks, alf
Nov 10, 2004 #2 ewh Aerospace Mar 28, 2003 6,130 0 36 US If your tube is a straight cylinder, you can use the wrap/unwrap command. Upvote 0 Downvote
