I am a fresh engineer at a thermal power plant and there is an ongoing issue with the turbine lube oil being dusty and moist nowadays here. There are two machines interchangeably being used for turbine lube oil tank. One is paper filtration-based machine using filter papers to remove the contaminants based on paper micron size etc. The other is moisture separation machine using centrifuging of oil to remove moisture, but the problem persists and becomes serious based on the duty hours of these machines. The engineer proposes the operation hours of these machines based on the NAS 1638 based test and the moisture PPM based tests. Where shall I be thinking around to propose a solution?
