Hi all,
I am having a little bit of trouble reading this spec, I have attached a view of the spec.
1) The view is from the governor, I'm assuming it's behind the inlet and outlet (they are on the same side). Where is the governor located?
2) Inlet Flange: "FORWARD FROM CENTERLINE OF EXHAUST OF 0.049".. What does that mean?
3) Lastly, what does "TURBINE SHAFT RISE AT STEAM AND BEARING 0.011" mean?
Thank you all in advance,
eng741
eng741
