Hi
I'm new in this forum, I need to learn to use Patran, and also, not now, Nastran..
In particular I have learn to make a mesh on a complex surface ( surface with complex curve hole and ...) , and at the and I make an op2 file, and use this file in other application.
I have some manual and but it is not satisfactorily. Can you recommend some tutorial? I need a tutorial both for beginner and for advanced use.
