Two directional bending and tension
Fernando799
Hi, i have a question, how to calculate a column when it is affected by two directional bendin and tension.
Ej:
Column 40x40 cm
Pu= -90kN Tension
Mux = 50knm
Muy = 90knm
Thx.
"column" not usually in tension. Superposition is handled in any text or google. Do you understand stress due to bending ? If you do, how do you think the two bending moments stresses will interact ? then adding tension should be easy. this is the student forum, but you have to put in some work. At least google it.
What are you trying to calculate and what material is this? I ask because if you're talking about concrete capacity design, this is actually a pretty complicated answer that doesn't necessarily pop up easily. It's the weird 'thing that you'd think is basic but is actually a giant giant pain' of structural engineering. It's not a superposition problem because of the composite nature of reinforced concrete.
Here's a reasonable example but there are simplified tabulated/charted approaches in the handbooks.
I guess mentioning "concrete" would help answering. At the same time I appreciate that the OP knows (or not) if the question is about concrete.
The tension is shown as -ve, does this mean it is compressive? If the material is linear can I take a punt and guess that Mohr's circle raises its annoying and long forgotten head?
Yes, its about concrete, and the tension is Tu=90kN, its not compresion.
I think Greg was talking about this ... I guess Pu defaults as compression, so -ve compression = tension ?
IDK concrete but I understand concrete is quite durable to compression, and quite intolerant to tension. Maybe you shouldn't superimpose stresses, but maybe use "utilization factors" = applied load / allowable load ??
Bi-axial bending in concrete is a massive main in the ass to do "accurately". Basically a 3d interaction diagram needs to be developped by changing the orientation/location of your neutral axis.
