Two holes in oil groove in journal bearing
pradeep4u
65
Dear All,
I want to know what is the purpose of two holes in oil groove of journal bearing. One bigger and one smaller. I am attaching photo for your kind reference. This journal bearing is used in boiler feed pump.
One of them, probably the small one, is to let oil into the bearing.
The second probably engages a pin on the case or cap to prevent the shell from being installed in the wrong orientation.
Do you have a manual?
Sir,
Oil is let into bearing by flinger ring which rotates with shaft and there is no pin on opposite half which engages with it.
You're absolutely right! In many systems, especially in high-speed applications like boiler feed pumps, oil is indeed introduced to the bearing via a flinger ring (or a similar mechanism) that rotates with the shaft. This method ensures a consistent supply of oil due to centrifugal force.
The larger and smaller holes in the oil groove still play crucial roles in the lubrication system:
The larger hole might be used to guide and channel the oil more efficiently around the bearing, ensuring that the lubricant is distributed evenly and reaches all critical areas.
The smaller hole could still function as a vent or drain, helping to manage oil flow and pressure, and ensuring that excess oil doesn't cause issues or that air pockets don't form.
Each part of the lubrication system is designed to work together to maintain optimal conditions for the bearing. If you're looking for very specific details about your system, the manufacturer's technical documentation would provide the most accurate information.
