Yunus9696
- Apr 14, 2022
- 47
Hello everybody
Hope you're doing great.
I have defined two interactions for a contact pair. The second interaction is created after the first one gets inactivated.
The first interaction is a Frictionless contact and the other is a Rough contact.
I keep getting the below-mentioned error while I submit the job.
I tried suppressing one of the above-mentioned interactions and the error was not reported again so I'm sure that the error is due to these two sequential interactions for the same contact pair.
THE *CONTACT PAIR pair (ASSEMBLY_SURF-A, ASSEMBLY_SURF-B) HAS BEEN PROCESSED BEFORE. REMOVE DUPLICATE PAIR. -- THE SAME PAIR OF SURFACES CANNOT BE SPECIFIED MORE THAN ONCE FOR *TIE AND *CONTACT PAIR. ONCE A PAIR OF SURFACES IS USED FOR *TIE, IT CANNOT BE USED AGAIN FOR *CONTACT PAIR AND VICE VERSA.
FYI, I don't have a tie constraint in the model.
Here I also attached my model's interaction manager window picture for more information.
Thanks for helping me out here.
Best regards,
Yunus.
Best regards,
Yunus.
