diegotorres1
- Sep 11, 2018
- 11
I am new to design (recently graduated), and i have been working on a project that has moment frames on all 4 sides of the building (rectangular one-story retail building) and on the short length walls, i have two moment frames on each side because the building has some pop up towers that take up a lot of the wind pressure. I would awesome that if two frames are in line, one of them will take more wind load and the other will see less because of the distribution of loading from the first frame leaving less for the second frame. Is there such a process so calculate such distribution based on the stiffness of the frame? i have brick veneer on the walls so i am limiting the drift of the moment frame to 1/2". any idea where i can look more into that?
