Jan 3, 2023 #1 3vessel Chemical Mar 24, 2009 1 0 0 IN I am doing two phase direct integration method calculations. can you share something which can help me.
Jan 3, 2023 #2 pierreick Chemical Nov 20, 2005 1,224 0 36 TH Hi, Consider this excel sheet to support your work. Note: I don't remember who created this document. I encourage you to develop your own. BTW consider reading in this forum the queries related to the subject. Good luck Pierre https://files.engineering.com/getfile.aspx?folder=00934f3d-f383-43c3-b27b-f07f30ca960c&file=PSV_Sizing_for_Two_Phase_Flow_Using_Direct_Integration_Method.xlsx Upvote 0 Downvote
Jan 7, 2023 1 #3 The Obturator Mechanical Feb 22, 2010 621 0 16 GB Refer to API-STD-520 Part I (2020) - Appendix C *** Per ISO-4126, the generic term 'Safety Valve' is used regardless of application or design *** *** 'Pressure-relief Valve' is the equivalent ASME/API term *** Upvote 0 Downvote
