Jdsavani
- Aug 30, 2019
- 1
Hi sir,
There is HP steam header in our plant. I have noticed water coming out from valve bonnet due to water and steam present at same time in pipe. But doesn't seems that steam should come out from valve bonnet as liquid remain on bottom side?
Similar problem found from flange gasket when steam and HC feed(in liquid state) flow at same time. Is there any case study where two phase flow had converted into accident ?
