Hi all,
I want to ask a question related to internal welded baffle plate for a two phase separator.
In order to calculate the plate thickness, I have currently used formulas available for rectangular plate of a tank given in Megeysey pressure vessel handbook
Is my approach correct? Is there any method to calculate the thickness of this welded baffle plate used for hold up of fluid and allowing separation of Air and oil
Design P: 150 Psig
Design T: 200 Deg C
MOC: Sa 516 70 (both for shell and internal baffle plate)
Design P: 150 Psig
Design T: 200 Deg C
