renzasaurus
- Jun 11, 2018
- 3
7-16 §12.2.3.2 permits the use of two-stage analysis, allowing the upper structures to be analyzed separately using equivalent lateral force method. Normally (non-two-stage analysis) mass at the base level would be assumed to dump right into the foundation (h = 0, thus Cvx = 0). My scenario is modular over concrete podium. The weight of the modular unit floor is non-insignificant and I want to anchor to the podium properly. How is this mass accounted for with regard to base anchorage in two-stage analysis then? Does my anchorage to the podium also need to be amplified by (R_upper / R_lower)? Would my upper structure "base" actually be h = height of floor framing = ~1', giving me a Cvx value (however small)?
