Dear All,
I would like to kindly inquire on the design of two stage centrifugal compressor (variable speed with suction pressure performance controller) which has each of its stages located in the same casing, driven by the same shaft and having common seal gas system. Each stage has its such cooler/gas-liquid scrubber and they are not segregated by shutdown valve, instead two dissimilar non slam check valves are provided at the discharge of the first stage in order to close fast in case of compressor shutdown preventing reverse over speed through the compressor.
My questions are as below:
1) I believe each stage shall have its standalone anti-surge control loop where the anti-surge line is taken from compressor discharge and connected upstream the suction cooler of each stage. This is in order to cover the process dynamics and reduce the surge event duration in case of the various blocked suction/outlet dynamic scenarios.
2) For designing the emergency depressurization system of the compressor and considering no SDV between the two stages and with standalone ASV for each stage,would you recommend having one blowdown valve common for the two stage compressor and located at the discharge of the 2nd stage compressor, what pressure levels we would consider while carrying out the blowdown out of the below:
a) 2nd stage settle out pressure directly to 7 barg considering the total system volume (1st stage+2nd stage) in 15 minutes
b) two segment depressurization taking the maximum flow out of : Segment 1: 2nd stage settle out pressure to 1st stage settle out pressure (with 2nd stage volume only) then segment 2: from 1st stage settle out pressure to 7 barg (total time shall be 15 minutes, RO size is fixed from segment 1).
3) Can we have one common anti-surge valve for both stages since they are located in the same casing and their overall settle out pressure will be used for setting the design pressure of the suction cooler/scrubber of the 1st stage compressor. I think in this case we may compromising surge protection due to the increase in system volume, delay in loop response time. Additionally, the design pressure of the inter stage scrubbers/cooler will have to be set only based on maximum 1st stage discharge pressure.
