Is it possible to have two installs of teamcenter running. I know you can have different versions of NX running on the same PC. Is this this possible with Teamcenter and does the license work for both or would you need license for each version. The situation we have is only certain divisions has teamcenter access at the moment and all are controlled globally. multiple divisions are working on a project and would like to experiment with a local install of teamcenter which has less requirements and controlled by the local department. All we are looking for are out of the box write protection and sharing. The global requirements are much more involved and timing of this project can not be implemented and employees trained in time. Is this possible technically?
Thanks in advance.
Thanks in advance.
