Trying to create a UDF for some clips and this is the error I get when I goto file -> export -> UDF -> wizard.
My first time really with UDF's too. But what I want to do is array those clips. The way I have them modeled in currently is just a revolution and extrusion. But it's die-locked and I want to keep it simple. So I started with the revolution and then hollowed it out.
Since you can't array things that have hollows on them, I was reading that I should just create a UDF and then array the UDF.
Anyways, thank you.
Justin Ackley
Designer
Anyways, thank you.
Justin Ackley
Designer
