UFER Ground
PracticingEngineer
12
What is a Ufer Ground in a foundation and who does it?
Check the NEC (National Electric Code) or your local electrical code. It is a secondary ground for the structure's electrical system. Around here they run a rebar or copper wire, in the footing pour, approximately 2" above grade. The bar length is around twenty feet and needs to be in place prior to the footing pour. The structure's electrical system is then grounded to the bar (or copper wire).
Who normally installs the Ufer-portion-rebar? I'm assuming the electrical contractor would install the copper if he were present. Thanks.
When I was the general contractor, we used the rebar option and I had the concrete subcontractor install the rebar. Custom probably varies in different locations.
