Fulbert
- Oct 20, 2015
- 1
hi,
Could someone explain me the undervoltage protection function in UFLS Relay?
I worked as an protection electrical maintenance engineer in both transmission and distribution.
Recently i faced with 1 issue regarding our UFLS Areva P923 Tripped on all stages (Stage1-6)without any fault on the network grid, i have checked the grid voltage systems and frequency with the operator found both are okay before the incident occured(1 minute before the incident).
We also have checked the VT's ratio & insulation and found okay. On the configuration relay P923 i found that the UV Blocking set to 5V where our nominal voltage is 63.5V(P-G)/110V(P-P). Can someone explain me the function?
TQ
TQ
