I have a question about how to interpret "d" which is defined as "diameter, or short span, measured as indicated in Figure UG-34" in relation to the two sketches (j and k) in the subject.
I've heard it a couple of different ways:
1) It appears that the line for d goes to the outer diameter of the hub of the flange that the blind is attached to, so therefore "d" is the hub outer diameter.
2) "HG" and "d" are both shown measured to the same line, and the definition for HG kicks you over to Appendix 2, Table 2-5.2, and that diagram shows "G", the gasket reaction diameter also being measured to the same line as "HG", therefore "d" is the same as "G" from Appendix 2.
Would love to hear from some folks on this.
