UG-34
mielke
181
In determining the thickness for a flat plate UG-34 has a constant 'C' for method of head to shell attachment.
We have a rectangular plate that is fully welded at its corners to four other plates that are perpindicular to the rectangular plate. (basically a box). what suggestions are there for the value of 'C' for the above description?
thank you
C=0.2 is right for this case. See Appendix 13, 13-4(f).
