thanooj82
- Jun 15, 2012
- 5
hai,
i am using NX-8,when i am doing vane finishing with a taper ball nose cutter (0.25")by using
variable contour--swarf drive option-- the tool is gouging with vane surface.then i adjusted the surface percentages and outside tolerances,still it is touching the vane surface.what method i have to use to finish the vane with out gouge.i added image for your reference.
with regards
t.tanooj
with regards
t.tanooj
