Creating a section line in NX/UG12 using locations only seen if hidden lines are shown. The section lines themselves turn the unassociated color if I turn the hidden lines to invisible to keep view not so busy because of all the hidden lines for the finished drawing.
Is there some setting I need to set so the section lines will stay associated with the hidden lines turned to invisible?
Thank you in advance for any advice.
