UG NX Sketch 1
geo12
99
Is there any way to change between diameter and radius when we click on the draw circle icon in the sketch mode.(the default is diameter)
Sometimes need to enter radius value.
Type an expression into the box (radius*2). For example, if the radius is '2.12345' you can type in '2.12345*2' into the diameter box. UG will evaluate the expression and use the result for the diameter value.
Thanks cowski,
That's what I am doing now. I am wondering whether there is an easy way to change the defaults between diameter and radius.
