patelam
- Jan 27, 2022
- 36
I have designed a beam for bending which is laterally supported over its length. This means that its governing failure in bending will be local inelastic buckling.
Does it means that we are allowing the beam to undergo inelastic zone when loaded to design load? Or the beam will still remain in elastic zone as there is enough margin created by the factor applied to the load?
