davidovitsh
In four point bending test, when loading a simply supported A36 steel beam to failure, where shear is very low and buckling is prevented, how much the ultimate bending moment is expected to diverge from the theoretical value: M=Fy.Z ?
Please, if any references for more readings are available then please include the links.
More info: I know the actual Fy and Fu of the steel section. And let's suppose that the failure is due to bending moment only, all other failures are prevented, how accurate M=Fy. Z will be? and does Fu contributes to the ultimate load?
