Ultra DMA 66
Guest
Hello I have ABIT BE6-II motherboard and it has a 2 ultra dma 66 which i am an internal zip drive to it. It works fine under win98 but I can't get it to work under Linux. Anybody has any idea?<br><br>OOzy<br>
You need to replace the IDE controller adres with HTP66 onboard controller address. You can do this with the startup keys. To find the correct keys for boot command try to install Mandrake distribution 6x or higher version with diskett boot. it will guide you about the correct keys.
