Un-Hide Parts in Sub Assemblies
jzecha
Aerospace
I have run into an issue with customer provided models loading in and not all the parts are visible.
So i created a macro that un-hides all the parts, it works great.
The only issue is that sometimes when I open the sub assemblies of the tool in a New Window in that Catia session, not everything is visible because the visual status is saved at the detail/sub assembly level.
Can someone recommend the best way to resolve this issue with just one Macro that I run once at the top level assembly?
Current Macro:
Code:
Language="VBSCRIPT"
Sub CATMain()
CATIA.DisplayFileAlerts = False
    Dim Message, Style, Title, Response, MyString
    Message = ("This macro will change the status of all CATParts  to SHOW " &_
                            (chr(13)) &_
                        ""&(chr(13))&_
"   Do you want to continue ?")
    Style = vbYesNo + vbDefaultButton1    'Define buttons. Button1 means marked by default
    Title = "Purpose "
    Response = MsgBox(Message, Style, Title)
        If Response = vbYes Then    ' User chose Yes.
            MyString = "Yes"
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Search "CATProductSearch.Assembly,all"  'show assemblies in product
Set visPropertySet1 = selection1.VisProperties
visPropertySet1.SetShow 0
selection1.Clear
selection1.Search "CATProductSearch.Part,all"  'show Parts in product
selection1.Clear
selection1.Search "CATAsmSearch.Part,all"  'show Parts in assembly
selection1.Clear
selection1.Search "CATPrtSearch.MechanicalFeature,all"
selection1.Clear
selection1.Search "CATPrtSearch.BodyFeature,all"  'show bodies in part
selection1.Clear
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
viewer3D1.Reframe
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
End If
CATIA.RefreshDisplay = True
End Sub
