Hello All -
Recently was upgraded to NX version 1980 and for whatever reason I can't use the bend command to select 2 points on the bend line anymore. If I click on the bend line nothing happens or executes.
In all of the previous versions I've worked with in 10 years, the standard process of creating a model from the original flat pattern has always been to Extrude, convert to sheet metal and bend.
I'm at a loss. Please advise and hopefully I can explain in more detail if need be.
Thanks in advance!
Thanks in advance!
