unable to import expression into nx created in excel sheet due to error
Are you using 2010 or 2013 or 2016. I do know that excel 2016 does not work with NX9.
Did the sheet ever work correctly? Your error message suggests that you don't have the column headings correct. Perhaps you should find a sheet that does work correctly and use that as your template.
TTFN (ta ta for now)
